Let Our On-Line Calculators do the work for you!
Engineers Edge Calculators
Engineering Basic Menu
The following tables provide conversion constants for length, area, volumes, liquid measures, weights measures and more.
Abbreviations may stand for singular or plural usage |
cm = centimeter
| cu. = cubic
| ft. = foot
| gal. = gallon (US) |
g. = gram
| Imp. = Imperial
| in. = inch
| kg. = kilogram |
km. = kilometer
| l. = liter
| lb. = pound
| m. = meter |
mi. = mile
| oz. = ounce
| qt. = quart
| std. = standard |
US = United States
| yd. = yard
LENGTH MEASURES |
Common Usage
Reciprocal Value
1 ft. = 12 in..
| 1 in. = 0.0833 ft.
1 yd. = 3 ft.
| 1 ft. = 0.3333 yd.
1 rod = 5.5000 yd.
| 1 yd. = 0.1818 rods
1 furlong = 40 rods
| 1 rod = 0.0250 furlongs
1 mile = 8 furlongs
| 1 furlong = 0.1250 mi.
1 mi. = 5,280 ft.
| 1 ft. = 0.000189 mi.
1 mi. = 1,760 yd.
| 1 yd. = 0.000568 mi.
1 fathom = 6 ft.
| 1 ft. = 0.1667 fathom
120 fathoms = 1 cable
| 1 cable = 0.00833 fathoms
1 league = 3 mi.
| 1 mi. = 0.3333 leagues
1 nautical mi. = 6076.11 ft.
| 1 ft. = 0.000165 nautical mi.
1 hand = 4 in. (equestrian)
| 1 in. = 0.2500 hands
METRIC |
1 in. = 2.54 cm.
| 1 cm. = 0.3937 in.
1 ft. = 30.48 cm.
| 1 cm. = 0.0328 ft.
1 m. = 3.2808 ft.
| 1 ft. = 0.3048 m.
1 m. = 39.37 in.
| 1 in. = 0.0254 m.
1 m. = 1.0936 yd.
| 1 yd. = 0.9144 m.
1 rod = 5.029 m.
| 1 m. = 0.1988 rod
1 km = 1000 m.
| 1 m. = 0.001 km.
1 km = 0.621 mi.
| 1 mi. = 1.6103 km.
SQUARE MEASURES |
Common Usage
| Reciprocal Value
1 sq. ft. = 144 sq. in.
| 1 sq. in = .006944 sq. ft.
1 sq. yd. = 9 sq. ft.
| 1 sq. ft. = 0.1111 sq. yd.
1 sq. rod = 30.25 sq. yd.
| 1 sq. yd. = 0.0331 sq. rods
1 sq. mi. = 640 acres
| 1 acre = 0.0016 sq. mi.
METRIC |
1 sq. cm. = 0.1550 sq. in.
| 1 sq. in. = 6.452 sq. cm.
1 sq. ft. = 0.0929 sq. m.
| 1 sq. m. = 10.7643 sq. ft.
1 sq. m. = 1.196 sq. yd.
| 1 sq. yd. = 0.8361 sq. m.
1 hectare = 2.47 acres
| 1 acre = 0.4049 hectares
1 sq. km. = 0.386 sq. mi.
| 1 sq. mi. = 2.59 sq. km.
CUBIC & VOLUME MEASURES |
Common Usage
| Reciprocal Value
1 cu. ft. = 1,728 cu. in
| 1 cu. in. = 0.0005787 cu. ft.
1 cu. yd. = 27 cu. ft.
| 1 cu. ft. = 0.0370 cu. yd.
1 cord (wood) = 128 cu. ft.
| 1 cu. ft. = 0.0078 cord
1 US std. gal. = 231 cu. in.
| 1 cu. in. = 0.00433 US std. gal.
METRIC
1 cu. in. = 16.39 cu. cm.
| 1 cu. cm. = 0.0610 cu. in.
1 cu. m. = 35.3357 cu. ft.
| 1 cu. ft. = 0.0283 cu. m.
1 cu. m. = 1.308 cu. yd.
| 1 cu. yd. = 0.7646 cu. m.
DRY MEASURES
1 qt. = 2 pints
| 1 pint = 0.5000 qt.
1 peck = 8 qt.
| 1 qt. = 0.1250 peck
1 bushel = 4 pecks
| 1 peck = 0.2500 bushels
METRIC
1 qt. dry = 1.101 l.
| 1 l. = 0.908 qt. dry
1 peck = 8.810 l.
| 1 l. = 0.1135 peck
1 hectoliter = 2.8375 bushels
| 1 bushel = 0.3524 hectoliters
LIQUID MEASURES
1 pint = 2 cup
| 1 cup = 0.5000 pints
1 qt. = 2 pints
| 1 pints = 0.5000 qt.
1 gal.. = 4 qt.
| 1 qt. = 0.2500 gal.
1 gal.. = 8 pints
| 1 pint = 0.125000 gal..
1 barrel = 31.5 gal..
| 1 gal.. = 0.0317 barrel
IMPERIAL & METRIC LIQUID MEASURE
1 US gal.. = 0.833 Imp. gal..
| 1 Imp. gal.. = 1.201 US gal..
1 Imp. gal.. = 4.546 l.
| 1 l. = 0.2200 Imp. gal..
1 l. = 0.264 US gal..
| 1 US gal.. = 3.7879 l.
1 l. = 1.0567 qt. liquid
| 1 qt. liquid = 0.9463 l.
1 gal.. = 3.7854 l.
| 1 l. = 0.2642 gal..
WEIGHT MEASURES |
Common Usage
| Reciprocal Value
1 lb. = 16 oz.
| 1 oz. = 0.0625 lb.
1 ton = 2000 lb.
| 1 lb. = 0.0005 ton
METRIC |
1 oz. = 28.35 g.
| 1 gr. = 0.03527 oz.
1 kg = 1000 gm
| 1 gr. = 0.001 kg.
1 lb. = 0.4536 kg.
| 1 kg. = 2.2046 lb.
1 metric ton = 0.9842 English ton
| 1 English ton = 1.016 metric tons
Temperature |
Celsius or Centigrade
| Fahrenheit
1 degree Celsius (C)
| 5/9 x (F - 32)
(9/5 x C) + 32
| 1 degree Fahrenheit (F) |
Air Density Calculation
- Std Air Density = 1.22556 and is defined at 59.0F degrees, 0.0% humidity, and 29.92 inches on the barometer.
- Temp C = (Temp-32.0) * 5.0 / 9.0;
- Temp K = Temp C + 273.0;
- Baro mb = Barometer / (29.92 / 1013.0);
- Baro pa = Baro_mb * 100.0;
- Saturation Pressure mb = 6.11 * pow(10,(7.5*Temp C)/(237.7+Temp_c));
- Vapor Pressure mb = Humidity * Saturation Pressure mb / 100.0;
- Temp Virtual K = Temp K / (1.0 - (Vapor Pressure mb/Baro_mb)*(1.-0.622))// D = P/(T*R)
- Air Density = Baro_pa / (Temp Virtual_k*GasConstant)% Std Density = Air Density/Std Air Density*100
Thermal Conductivity Conversions:
1 cal/cm2/cm/sec/C = 10.63 watts/in - C
117 BTU/(hr-ft-F) x (.293 watt-hr/BTU) x (1.8F/C) x (ft/12 in.) = 5.14 watts/in - C
or
117 Btu / (hr-ft-F) x .04395 watt-hr-F-ft/(Btu=C - in) = 5.14 watts/in-C
