Hydraulic Scissor Lift Design Project
Beam Deflection and Stress Calculators Formulas & Structural Analysis
Nikhil Rane
Faculty of Technology and Bionics
Rhine-Waal University of Applied Sciences
Kleve, Germany
2021
Introduction
This project describes the design calculation of a Hydraulic Scissor Lift. Usually, a scissor lift is used to lift a certain object to a certain height example- for lifting a car to change a tire. A scissor lift can be pneumatic, mechanical or hydraulic. In the following chapter first forces are determined at the scissor legs. After which stress and strain analysis is performed. Last part of this project will be weld analysis done at clevis of the hydraulic piston.
Open and view: Hydraulic Scissor Lift Design Project
Boundary Conditions
A basic model of the scissor lift is made in Solid Works by keeping in mind the following boundary conditions-
• Constant load of 5KN is acting at 25% and 75% of table length
• Weight of table is considered to be 41.2 kg (Material of S355J2G3 is considered)
• Weight of components other than table are neglected • Foot print of the lift should not exceed 1000 x 500 mm
• A general design for hydraulic piston is considered
• Maximum height the lift can go (h_max) = 750 mm
• Minimum height the lift can go (h_min) = 350 mm
TOC
1 FBDs ........ 6
1.1 Introduction... 6
1.2 Boundary Conditions .... 6
1.3 Setup ............. 6
1.4 Reaction Forces on Table ........... 7
1.4.1 Case 1 – at h_max, Load at 25% of of Table length .. 7
1.4.2 Case 2 – at h_max, Load at 75% of of Table length .. 8
1.4.3 Case 3 – at h_min, Load at 25% of of Table length ... 9
1.4.4 Case 4 – at h_min, Load at 75% of of Table length . 10
1.4.5 FBD of Scissor Legs AB and CD together. 11
1.4.6 Free body Diagram of Scissor Leg CD...... 12
1.4.7 Case 1 .......... 14
1.4.8 Case 2 .......... 16
1.4.9 Case 3 .......... 19
1.4.10 Case 4 .......... 21
2 Stress Analysis .... 25
2.1 Stress calculation ....... 25
2.1.1 Scissor Legs AB .......... 25
2.1.2 Calculation for ........ 27
2.1.3 Calculation for ........ 27
2.1.4 Calculation for ......... 27
2.1.5 Calculation for ....... 27
2.1.6 Safety check . 28
3 Weld Analysis ...... 29
3.1.1 Calculation for ......... 30
3.1.2 Calculation for ........ 30
3. 1.3 Calculation for
3.1.4 Calculation for ....... 31
3.1.5 Safety check . 31
4 Assembly Drawing.............. 33
5 References ............. 34
