Beam Deflection and Stress Equations for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports
Shear, Deflection and Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports
Beam Bending Moments Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Beam Load, Total lbf (N)
w = Beam Unit Load lbs/in (N/mm)
Vmax = Shear Load lbf (N)
Mmax = Beam Moment lbs-in (N-mm)
σmax = Beam Stress max. psi (N/mm2)
