Offset Link Stress Calculator for Compression
Combined Loading Offset Link, Rectangular Section, in Direct Compression Stress Equation and Calculator:
Combined Loading Offset Link, Rectangular Section, in Direct Tension Stress
Maximum Nominal
Shear Stress
b = Base inches (mm)
h = Height inches (mm)
e = Distance inches (mm)
F =
Applied Load lbs (N)
σ' a =
Stress, Tensile or Compressive Lbs/in2 (N/mm2)
σ' b = Stress, Tensile or Compressive Lbs/in2 (N/mm2)
τ'a = Stress, Max. Nominal Shear Lbs/in2 (N/mm2)
τ'b = Stress, Max. Nominal Shear Lbs/in2 (N/mm2)
  1. Any Machinery's Handbook published since 1931 or,
  2. Machinery's Handbook, 21st Edition, Page 404 or,
  3. Machinery's Handbook, 23st Edition, Page 260 or,
  4. Machinery's Handbook, 27st Edition, Page 261
