Bending, Deflection and Stress Equations Calculator for
Both Ends Overhanging Supports, Load at any Point Between
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with Both Ends Overhanging Supports, Load at any Point Between.
Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Stress
Stress at Load:
If cross-section is constant, this is the maximum stress.
Open: Stress at Load Beam Calculator
General Stress at any Given Point
Between supports:
For area length a,
Open: Stress Between Supports Length a Beam Calculator
For area of length b,
Open: Stress Between Supports Length b Beam Calculator
Beyond supports s = 0
Deflection at Critical Locations/Points
Deflection at any Point
Between supports for overhanging end of length c
Open: Deflection overhanging end of length c Beam Calculator
for overhanging end of length d
Open: Deflection overhanging end of length d Beam Calculator
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
u = Some distance as indicated inches (mm)
a, b, c & d = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
