Deflection Moment Equations and Calculator Beam Supported Partial Tapering Load Applied
Stress Deflection Moment Equations and Calculator Beam Supported Partial Tapering Load Applied Equation and Calculator
Preview: Deflection, Shear, Moment Calculator
Reaction and Shear Equation
Bending Moments Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
y = Deflection inches (mm)
Vmax = Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
  • Young, W. C., Budynas, R. G.(2002). Roark's Formulas for Stress and Strain . 7nd Edition, McGraw-Hill.
