Beam Stress Deflection Strain Equations and Calculator Beam Supported Tapering Load Applied
Beam Deflection, Stress, Strain Equations and Calculators
Preview Beam Stress Deflection Strain Equations and Calculator Beam Supported Tapering Load Applied
Reaction and Shear Equation
Bending Moments Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
y = Deflection inches (mm)
Vmax = Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
