Torsional Deflection of Shaft
Mechanics of Machine Design, Equations and Calculators
Angular Deflection of Solid Cylinder or Shaft with Torsion Applied
Torsional Deflection of Cylinder
The angular deflection of a solid cylinder with torsion loading applied:
θ = L T / (G J )
Open Torsional Deflection of Shaft Calculator
θ = angular shaft deflection (radians)
T = torque (N-mm, in-lb)
L = length of shaft (mm, in)
G = modulus of rigidity (Mpa, psi)
J = Polar moment of inertia (mm4, in4)
#2 Equation and Calcuator for Angular Deflection of Solid Cylinder or Shaft with Torsion Applied
θ = 32 L T / (G π D4)
The angle in degrees can be achieved by multiplying the angle θ in radians with 180/π
Solid shaft (π substituted)
θdegrees ≈ 584 L T / (G D4)
Open Angular Deflection of a Torsion Solid Shaft Calculator
D = outside diameter (mm, in.)
Angular Deflection of Hollow Shaft or Cylinder Equation and Calculator
Torsion Rigidity
Open Angular Deflection of Hollow Shaft Calculator
The angular deflection of hollow shaft
θ = 32 L T / (G π (D4- d4))
d = inside diameter (mm, in.)
Hollow shaft (π substituted)
θdegrees ≈ 584 L T / (G (D4- d4)
Reference
Shigley, J. E., Machine Design, McGraw-Hill Publishing Company, New York, 1956.
