Polar Area Moment of Inertia, Polar Section Modulus Properties of Common Shapes
Engineering Metals and Materials Table of Contents
Engineering Analysis Menu
Polar Area Moment of Inertia and Section Modulus.
The polar moment of inertia, J, of a cross-section with respect to a polar axis, that is, an axis at right angles to the plane of the cross-section, is defined as the moment of inertia of the cross-section with respect to the point of intersection of the axis and the plane. The polar moment of inertia may be found by taking the sum of the moments of inertia about two perpendicular axes lying in the plane of the cross-section and passing through this point.
The polar section modulus (also called section modulus of torsion), Zp, for circular sections may be found by dividing the polar moment of inertia, J, by the distance c from the center of gravity to the most remote fiber. This method may be used to find the approximate value of the polar section modulus of sections that are nearly round. For other than circular cross-sections, however, the polar section modulus does not equal the polar moment of inertia divided by the distance c.
Related: Polar Mass Moment of Inertia About Axis A-A, Axis B-B and Axis C-C.
All calculators require a java enabled browser and a Premium Membership Account.
Section
Polar Area
Moment of Inertia
J
Polar Area
Section Modulus
Zp
Square Section
Area Polar Moment of Inertia
Square Section
Square Section Polar Equation
Rectangle Section
Rectangle
polar Moment Equation 2
(d is shorter dimension)
Circular Section
Circle Section
Polar Moment of inertia
Tube Section
Tube
Open
Tube Section Polar Moment of Inertia Calculator
Hexagon Section
Penta
Open
Hexagon Section Polar Moment of Inertia Calculator
= 0.12 F4
0.20 F3
Circle with Square Cutout Section
Square Drive
Open
Circle with Square Cutout Section Polar Moment of Inertia Calculator
= 0.098 D4 - 0.167 s4
Circle with Socket Head Cutout
Section Area Polar Moment of Inertia
Socket Head
Open
Circle with Socket Cutout Section Polar Moment of Inertia Calculator
0.098 D4 - 1.0825 s4
Triangular Section
Trinagle
Open
Triangular Section Polar Moment of Inertia Calculator
www.engineersedge.com
Advertising | Contact
