heat loss from a pipe calculator
Heat Transfer Engineering
Equations and calculator to determine the conductive heat loss from a cylinder or pipe of known length.
The temperature gradient within a homogeneous material results in an energy transfer rate within the medium which can be calculated with the following equation
Heat Loss equation eq. a
Insulated Pipe
The illustration above depicts a single-layer cylindrical wall of a homogeneous material with constant thermal conductivity and uniform inner and outer surface temperatures. At a given radius the area normal to radial heat flow by conduction is 2 Π r L, where L is the cylinder length. Substituting this into (eq. a) and integrating with q constant gives:
Delta tempaeratureeq. 0
or
eq. 1
thus
Heat loass equation eq 2
Preview Heat Loss From Pipe Calculator
k = thermal conductivity (Btu / h · in· °F)
L = length of cylinder and insulation layer (in)
r = radius
q = conduction (Btu / h · °F)
Contribute Article
User Reviews/Comments:
By: amiruulah - Nov 18, 2015
can you show me how to calculate the Hs?
By: mom - Sep 5, 2015
what equation did you use for calculating surface heat transfer coefficient?
By: Henock Daniel - Jul 24, 2014
Do=23.75",Ds=24", K=46.33 btu/hr-ft-F
Tf=105F, Ta=54.5F
q=1292.8 Btu/hr*ft based on your equation but am getting 1400919.9 Btu/hr*ft with excel
Thanks
Name:
Email: (Optional)
Comment:
