Heat Exchanger Design and Engineering
Heat Exchanger Companies Suppliers | Engineering Analysis Menu
  • The following are to links of Heat Exchanger related tools, articles and other useful data.
  • Should you find any errors omissions broken links, please let us know - Feedback
  • Do you want to contribute to this section? See Premium Publisher Program
Heat exchangers are engineered hardware for the efficient heat transfer from one medium to another. The media may be separated by a solid wall to prevent mixing or they may be in direct contact. They are widely used in space heating, refrigeration, air conditioning, power plants, chemical plants, petrochemical plants, petroleum refineries, natural gas processing, and sewage treatment. The classic example of a heat exchanger is found in an internal combustion engine in which a circulating fluid known as engine coolant flows through radiator coils and air flows past the coils, which cools the coolant and heats the incoming air.
Contribute Article
