Parallel Flow Type Heat Exchanger
Heat Transfer Engineering | Heat Exchanger Knowledge
Heat Exchanger Companies Suppliers
Counter & Parallel Flow Heat Exchanger Calculator
Parallel flow, as illustrated below, exists when both the tube side fluid and the shell side fluid flow in the same direction. In this case, the two fluids enter the heat exchanger from the same end with a large temperature difference. As the fluids transfer heat, hotter to cooler, the temperatures of the two fluids approach each other. Note that the hottest cold-fluid temperature is always less than the coldest hot-fluid temperature.
