Heat Conduction Wall Equations and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Heat Conduction through a wall equations and calculator.
Heat Conduction Through Wall
Preview: Heat Conduction through a Wall Calculator
Variation in thermal conductivity of a material with temperature in the temperature range of interest can often be approximated as a linear function and expressed as:
k(T) = Variation in thermal conductivity (W/m • K)
β = Temperature Coefficient of Thermal Conductivity (K-1)
ko = Thermal Conductivity (W/m • K)
T = Temperature (K)
Average Thermal Conductivity
Example Heat Conduction through a Wall with k(T )
2-m-high and 0.7-m-wide bronze plate whose thickness is 0.1 m. One side of the plate is maintained at a constant temperature of 600 K while the other side is maintained at 400 K. The thermal conductivity of the bronze plate can be assumed to vary linearly in that temperature range as k (T) = ko(1  βT ,) where ko = 38 W/m · K and β 9.21 10-4 K-1. Disregarding the edge effects and assuming steady one-dimensional heat transfer, determine the rate of heat conduction through the plate.
Assumptions:
1 Heat transfer is given to be steady and one-dimensional.
2 Thermal conductivity varies linearly.
3 There is no heat generation.
therefore
Rate of THermal Conduction
Then the rate of heat conduction:
A = Area (m2) = H x W
L = Thickness (m)
