Sure-Fit or Extreme Variability Formulae and Calculator
Sure-Fit or Extreme Variability of Mechanical Tolerances Calculator
The sure-fit or extreme variability of a function of several uncorrelated random variables could be found by substituting values for the variables to find the maximum and the minimum value of the function
Preview Sure-Fit Mechanical Tolerance Design Calculator
y = ( x1 + 2 · x2 ) / x33
The maximum value of ymax is given by:
ymax = ( x1,max + 2 · x2,max ) / x33,min
Similarly for the minimum value:
Eq. 3
ymin = ( x1,min + 2 · x2,min ) / x33,max
The sure-fit or extreme variability can then be determined as:
Eq. 4
Δy = ymax - ymin
Approximation extreme variability.
Eq. 5
Δy = | y / x1 | Δx1 + | y / x2 | Δx2 + | y / x3 | Δx3
Eq. 5a
Δx1 = x1,max - x1,max
Eq. 5b
Δx2 = x2,max - x2,min
Eq. 5c
Δx3 = x3,max - x3,min
  • Mechanical Design, 2nd edition
    Peter R. N. Childs
