Beam Stress and Deflection Equations Calculator for End Overhanging Supports and a Single Load
To see the equations and applicable units behind this calculator see:
Beam Bending Equations for Calculator
This calculator will determine the stress, deflections, area moment of inertia, and section modulus for a Beam ends overhanging supports on both ends and a single load applied at overhang.
Beam Deflection and Stress Equations Calculator
Design Variables
Modulus of Elasticity lbs/in2 (N/mm2) E =
Moment of Inertia in4 (mm4) I =
Load lbs (N) W =
Distance in. (mm) c =
Distance in. (mm) d =
Distance in. (mm) w =
Distance in. (mm) u =
Distance in. (mm) l =
Distance in. (mm) x =
Distance to neutral axis/plane in. (mm) z =
Results
Load at support [(W(c + l)]/l =
Load at support -(Wc)/l =
Stress between nearest support lbs/in2 (N/mm2) s =
Stress between the two supports lbs/in2 (N/mm2) s =
Stress at the support nearest the load lbs/in2 (N/mm2) s =
Deflection between load nearest (adjacent support) (y) =
Deflection between supports in. (mm) y =
Deflection between non-loaded end and nearest support in. (mm) y =
Deflection at the load in. (mm) y =
Deflection at the unloaded ends in. (mm) y =
Section Modulus in3 mm3) Z =
Automatic recalculation
