Conductive Heat Transfer Two Adjoining Walls Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Conductive Heat Transfer of the edge of two adjoining walls of equal thickness
Preview: Conductive Heat Transfer Two Adjoining Walls Calculator
Thermal Conduction Equation
Steady State Constant
T1 = Temperature (°C)
T2 = Temperature (°C)
L = Length / Thickness (m)
w = Width (m)
