Related Resources: fluid flow
Ductile Iron Pipe Sizes and Dimensions
Dimensions of Ductile Iron Pipe Special Pressure Classes (customary U.S. units)
Iron Pipe per. ANSI/AWWA C150/A21.50 and ANSI/AWWA C151/A21.51
Nominal sizea
(in)
Outside
Diameter
(in)
Minimum wall thickness (in)
special pressure classb
50
51
52
53
54
55
56
4
4.80
0.26
0.29
0.32
0.35
0.38
0.41
6
6.90
0.25
0.28
0.31
0.34
0.37
0.40
0.43
8
9.05
0.27
0.30
0.33
0.36
0.39
0.42
0.45
10
11.10
0.29
0.32
0.35
0.38
0.41
0.44
0.47
12
13.20
0.31
0.34
0.37
0.40
0.43
0.46
0.49
14
15.30
0.33
0.36
0.39
0.42
0.45
0.48
0.51
16
17.40
0.34
0.37
0.40
0.43
0.46
0.49
0.52
18
19.50
0.35
0.38
0.41
0.44
0.47
0.50
0.53
20
21.60
0.36
0.39
0.42
0.45
0.48
0.51
0.54
24
25.80
0.38
0.41
0.44
0.47
0.50
0.53
0.56
30
32.00
0.39
0.43
0.47
0.51
0.55
0.59
0.63
36
38.30
0.43
0.48
0.53
0.58
0.63
0.68
0.73
36
38.30
0.43
0.48
0.53
0.58
0.63
0.68
0.73
48
50.80
0.51
0.58
0.65
0.72
0.79
0.86
0.93
54
57.56
0.57
0.65
0.73
0.81
0.89
0.97
1.05
(Multiply in by 25.4 to obtain mm.)
(Multiply lbf/in2 by 6.895 to obtain kPa.)
aFormerly designated “standard thickness classes.” These special pressure classes are as shown in AWWA C150 and C151. Special classes are most appropriate for some threaded, grooved, or ball and socket pipes, or for extraordinary design conditions. They are generally less available than standard pressure class pipe.
b60 in (1500 mm) and 64 in (1600 mm) pipe sizes are not available in special pressure classes.
Reference
