Schedule 40 Plastic PVC, CPVC and Other Pipe Sizes & Dimensions
Fluid Flow Table of Contents
Schedule 40 Plastic PVC, CPVC and Other Pipe Sizes and Dimensions | Schedule 40 Pipe
APPLICATION
CPVC IPS sizes 1/4" through 24", for use at temperatures up to and including 200°F. Pressure rating (130 psi to 1130 psi) varies with schedule, pipe size, and temperature. Rresistant to most acids, bases, salts, aliphatic solutions, oxidants, and halogens.
References: ASTM STANDARD D1784 MATERIAL EQUIVALENTS: Cell Classification 23447 = CPVC Type IV Grade 1 = CPVC 4120
Chart gives dimensional - size data for PVC, CPVC and other Schedule 40 Plastic Pipe.
Nominal Size (in)
Outside Diameter (in)
Schedule 40
Wall Thickness (in)
Weight
PVC
(lb/100 ft)
Weight
CPVC
(lb/ 100 ft)
Max.
Pressure
PSI
1/8
.405
.072
810
1/4
.540
.093
780
3/8
.675
.096
620
1/2
.840
.116
16
17
600
3/4
1.050
.120
21
23
480
1
1.315
.141
32
34
450
1 1/4
1.660
.148
43
46
370
1 1/2
1.900
.154
51
55
330
2
2.375
.163
58
74
280
21/2
2.875
.215
107
118
300
3
3.500
.229
141
154
260
3 1/2
4.000
.240
201
220
240
4
4.500
.251
273
220
5
5.563
.273
353
386
190
6
6.625
.297
539
581
180
8
8.625
.341
755
824
160
10
10.75
.387
1001
1089
140
12
12.75
.430
1180
130
14"
14.000
.456
1180
130
16"
16.000
.512
1543
130
18"
18.000
.572
130
20"
20.000
.601
120
24"
24.000
.697
120
