Bearing Load Calculator
Bearing Load Calculator Excel Spreadsheet
Description:
This design engineering spreadsheet calculates the loads on linear motion bearings. It takes forces applied at the cutting tool and bearing locations (X,Y,Z) as inputs. The X-Y center of the work volume, at the table height, is defined as the origin. All dimensions in inches. All forces in lbf. NOTE: If a bearing is not used (e.g. Bearing 4 in 3-bearing stage), clear cells rather than zeroing.
