Measuring Radius of Arc Formula and Calculator
Measuring Radius of Arc With Gage Pins or Plugs Formula and Calculator
Preview Measuring Radius of Arc Calculator
Figure 2, Measuring Convex Radii
Figure 2, Measuring Concave Radii
An accurate method of finding or checking the radius on a part is illustrated in Figs. 1 and 2. In this method, we may calculate either an inside or an outside radius by the following equations:
for convex radii,
r = ( L + D )2 / ( 8 · D )
for concave radii,
r = ( L + D )2 / [ 8 ( h - D ) ] + h / 2
where
L = length over gage pin or plugs, in (mm)
D = diameter of gage pin or plugs, in (mm)
h = height of concave high point above the gage pin or plugs, in (mm)
For accuracy, the rolls or plugs must be placed on a tool plate or plane table and the distance L across the rolls measured accurately. The diameter D of the rolls or plugs also must be measured precisely and the height h measured with a telescoping gauge or inside micrometers.
Handbook of Machining and Metal Working Calculations
2001
Ron A. Walsh
