Engineers Edge
Bolt Circle With Odd Number of Holes Within Circle
Measurement and Conversion Calculator #3
Strength of Materials
For more quations and illustrative graphics see:
Measuring Large Bolt Circle Equations and Review
To measure the unknown distance x over semi-opposite holes using pins (largest gage pins that can fit into holes) and the number of holes n is odd and greater than 3, and the distance c between adjacent holes (pins) is known as shown left in Illustration C, use the equation:
c = the distance over adjacent pins
d = the diameter of the holes
θ = 360°/n or angle between adjacent holes.
All units shall be consistant and given in inches or mm. Angles (theta) are given in degrees
Variables
Distance over alternate pins (c) =??
Diameter of holes (d) =
Angle between adjacent holes (Theta) =
Results
Distance over opposite pins (x) =
