Frame Deflections Lateral Displacement Applied to Left Vertical Member Equations and Calculator
Frame Deflections with Concentrated Lateral Displacement Applied to Left Vertical Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Lateral Displacement Applied to Left Vertical Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
LPH = Δo (1) - Note: Δo could also be represented as a decrease in l3 length.
LPM = 0
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
