Tangential Loading Smooth Figure of Revolution Equations and Calculator
Any smooth figure of revolution if R2 is less than infinity Stress and Deflection Equation and Calculator.
Tangential Loading Only, resultant load = P
Preview: Smooth Figure of Revolution Stress and Deflection Calculator
Smooth Figure of
Revolution
For R2 / t > 10
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Rotation of a meridan from its unloaded position
Where used:
v = Poisson's ratio
P = Axial load or force (lbs)
σ1,2 = Stress, (lbs/in2)
R1 = Radius (in)
R2 = Radius (in)
t = Wall thickness (in)
y = Vertical level from bottom of vessel (in)
θ = Angle (deg.)
