Cylindrical Shaft and Maximum Torque Moment
Srength Mechanics of Materials
In solid mechanics, torsion is the twisting of an object due to an applied torque. It is expressed in newton millimeters (N·m) or inch-pound force (in·lbf). In sections perpendicular to the torque axis, the resultant shear stress in this section is perpendicular to the radius.
Cylindrical Shaft Torque Hollow Shaft Max Torque
Maximum moment applied to a cylindrical shaft:
Tmax = σmax Ip / R
Tmax = maximum torque moment (N-mm, in-lb)
σmax = maximum shear stress (MPa, psi)
R = radius of shaft (mm, in)
Solid cylindrical shaft
Tmax = (π / 16) σmax D3
Hollow cylindrical shaft
Tmax = (π / 16) σmax (D4 - d4) / D
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
