Engineers Edge
Cylinder Stress and Deflection with Applied Torsion
Strength / Mechanics of Materials Menu
The following are the equations and a calculator for determining the cylinder stress and deflection with a known applied torsion or torque. Please note that you must have a java enabled browser. To update the calculated values after changing inputs, you must click "Calculate" located at the bottom of the web page.
Reference: Roark's Formulas for stress and Strain 7th edition Warren C Young - Table 10.1
Cylinder Torsion Stress
Application Illustration
  Shaft Data
r =
mm
degs
h =
  Rotational Moment
T =
Nmm
  Length under torsion
L =
mm
  Young's modulus
E =
N/mm2
  Poissons ratio
v =
  Modulus of rigidity
G =
  Torsion constant
C =
K =
  Angular Deflection
  Maximum sheer stress (at perimeter)
B =
B =
