Engineers Edge
Torsional Deflection of Cylinder Calculator
Strength / Mechanics of Materials
In solid mechanics, torsion is the twisting of an object due to an applied torque. It is expressed in newton metres (N·m) or foot-pound force (in·lb). In sections perpendicular to the torque axis, the resultant shear stress in this section is perpendicular to the radius.
Shear Stress in Shafts Equations
Shear Stress in Solid Shaft
Variables
Applied Torque T (N-mm, in-lb) =
Distance Center to Stressed Surface (mm, in) =
Polar Moment of Inertia" of Cross Section (mm4, in4) =
Results
Shear Stress (MPa, psi) =
Example calculations are in imperial units (in-lbs, psi, etc.)
