Related Resources: fluid flow
Steel Pipe Flow Loss Friction for sizes 4 " to 8 " inch diameter
Tables are for steel pipe with a surface roughness of C=100.
See also
To adjust for different surface roughness factors, use the following correction factors:
Value of C
150
140
130
120
110
100
90
80
70
60
0.47
0.54
0.62
0.71
0.84
1.00
1.22
1.51
1.93
2.57
Friction Losses in Pipe: Standard Weight Steel 4" Dia.
Pipe Size, in. 4
Pipe Dia., in.
4.026
Velocity, fps
Surface Rough C
100
hd. loss, ft/100 ft
gpm
65
1.64
0.54
70
1.76
0.62
75
1.89
0.70
80
2.02
0.79
85
2.14
0.88
90
2.27
0.98
95
2.39
1.08
100
2.52
1.19
110
2.77
1.42
120
3.02
1.67
130
3.28
1.93
140
3.53
2.22
150
3.78
2.52
160
4.03
2.84
170
4.28
3.2
180
4.54
3.5
190
4.79
3.9
200
5.04
4.3
210
5.29
4.7
220
5.54
5.1
230
5.80
5.6
240
6.05
6.0
260
6.55
7.0
280
7.06
8.0
300
7.56
9.1
Friction Losses in Pipe: Standard Weight Steel 5 " Dia.
Pipe Size, in. 5.0
Pipe Dia., in.
5.047
Velocity, fps
Surface Rough C
100
hd. loss, ft/100 ft
gpm
160
2.57
0.95
170
2.73
1.06
180
2.89
1.18
190
3.05
1.30
200
3.21
1.43
210
3.37
1.56
220
3.53
1.70
230
3.69
1.85
240
3.85
2.00
260
4.17
2.32
280
4.49
2.66
300
4.81
3.0
320
5.13
3.4
380
6.09
4.7
400
6.41
5.2
420
6.74
5.6
440
7.06
6.1
460
7.38
6.7
480
7.70
7.2
500
8.02
7.8
520
8.34
8.4
540
8.66
9.0
560
8.98
9.6
580
9.30
10.2
600
9.62
10.9
Friction Losses in Pipe: Standard Weight Steel 6 " Dia.
Pipe Size, in. 6
Pipe Dia., in. 6.065 Velocity, fps
Surface Rough C
100
hd. loss, ft/100 ft
gpm
220
2.44
0.70
240
2.67
0.82
260
2.89
0.95
280
3.11
1.09
300
3.33
1.24
320
3.55
1.39
380
4.22
1.92
400
4.44
2.11
420
4.66
2.31
440
4.89
2.51
460
5.11
2.73
480
5.33
3.0
500
5.55
3.2
520
5.77
3.4
540
6.00
3.7
560
6.22
3.9
580
6.44
4.2
600
6.66
4.5
650
7.22
5.2
700
7.77
5.9
750
8.33
6.7
800
8.88
7.6
850
9.44
8.5
900
9.99
9.4
950
10.55
10.4
Friction Losses in Pipe: Standard Weight Steel 8 Dia.
Pipe Size, in. 8
Pipe Dia., in. 7.981 Velocity, fps
Surface Rough C
100
hd. loss, ft/100 ft
gpm
460
2.95
0.72
480
3.08
0.78
500
3.21
0.84
520
3.33
0.90
540
3.46
0.97
560
3.59
1.03
580
3.72
1.10
600
3.85
1.17
650
4.17
1.36
700
4.49
1.56
750
4.81
1.77
800
5.13
2.00
850
5.45
2.23
900
5.77
2.48
950
6.09
2.74
1,000
6.41
3.0
1,050
6.73
3.3
1,100
7.05
3.6
1,150
7.38
3.9
1,200
7.70
4.2
1,250
8.02
4.6
1,300
8.34
4.9
1,350
8.66
5.3
1,400
8.98
5.6
1,450
9.30
6.0
Source
