EUE Tubing Torque Table
Fluids Engineering Data
Recommended Torque Table for UEU Tubing
API EUE = External Upset End tubing connections. The EUE joint has a designed joint strength in tension and pressure strength greater than that of the pipe body and, therefore, is considered a 100% joint efficient connection. For proper lubrication and sealing, the joint requires thread compound as defined in API RP 5A3 . To improve the seal performance of API EUE tubing in high-pressure service, a grooved coupling, which accepts nonmetallic seal rings, is sometimes used in the coupling (see API Spec. 5CT SR 13 ). To provide more clearance, API special clearance EUE couplings are available. API EUE joints come in OD sizes of 1.050 to 4.500 in.
SIZE DIA. WT/FT GRADE TORQUE FT-LBS
MIN. OPT. MAX.
1" 1.8 J-55 430 570 710
1" 2.8 N-80 590 790 990
1 1/4" 2.4 J-55 520 690 860
1 1/4" 2.4 N-80 720 960 1200
1 1/2" 4.7 J-55 660 880 1100
1 1/2" 4.7 N-80 920 1220 1530
2 3/8" 4.7 J-55 970 1290 1610
2 3/8" 4.7 N-80 1350 1800 2250
2 3/8" 4.7 L-80 1320 1760 2200
2 3/8" 4.7 13CR-85 1400 1860 2330
2 3/8" 4.7 13CR-110 1785 2380 2975
2 3/8" 4.7 P-110 1785 2380 2975
2 3/8" 5.95 N-80 1680 2240 2800
2 3/8" 5.95 L-80 1640 2190 2740
2 3/8" 5.95 13CR-85 1740 2320 2900
2 3/8" 5.95 13CR-110 2210 2950 3680
2 3/8" 5.95 P-110 2210 2950 3680
2 7/8" 6.5 J-55 1240 1650 2060
2 7/8" 6.5 N-80 1730 2300 2880
2 7/8" 6.5 L-80 1690 2250 2810
2 7/8" 6.5 13CR-85 1785 2380 2975
2 7/8" 6.5 13CR-110 2280 3040 3800
2 7/8" 6.5 P-110 2280 3040 3800
2 7/8" 7.9 N-80 2080 2770 3470
2 7/8" 7.9 L-80 2030 2710 3390
2 7/8" 7.9 13CR-85 2150 2870 3590
2 7/8" 7.9 13CR-110 2750 3660 4580
2 7/8" 7.9 P-110 2750 3660 4580
2 7/8" 8.7 N-80 2270 3020 3780
2 7/8" 8.7 L-80 2210 2950 3690
2 7/8" 8.7 13CR-85 2340 3120 3900
2 7/8" 8.7 13CR-110 2985 3980 4975
2 7/8" 8.7 P-110 2985 3980 4975
3 1/2" 9.3 J-55 1710 2280 2850
3 1/2" 9.3 N-80 2400 3200 4000
3 1/2" 9.3 L-80 2350 3130 3910
3 1/2" 9.3 13CR-85 2480 3310 4140
3 1/2" 9.3 13CR-110 3170 4230 5290
3 1/2" 9.3 P-110 3170 4230 5290
3 1/2" 12.95 N-80 3220 4290 5360
3 1/2" 12.95 L-80 3150 4200 5250
3 1/2" 12.95 13CR-85 3340 4450 5560
3 1/2" 12.95 13CR-110 4260 5680 7100
3 1/2" 12.95 P-110 4260 5680 7100
4" 11 J-55 1920 2560 3200
4" 11 N-80 2700 3600 4500
4" 11 L-80 2650 3530 4410
4" 11 13CR-85 2800 3730 4660
4 1/2" 12.75 J-55 2150 2860 3580
4 1/2" 12.75 N-80 3020 4020 5030
4 1/2" 12.75 L-80 2960 3940 4930
4 1/2" 12.75 13CR-85 3130 4170 5210
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
