Engineers Edge
Pressure Vessel Wall Thickness with Internal Pressure Applied Calculator
This calculator determines the thickness of a circumferential shell with an internal pressure applied: Typical applications are propane tanks, compressed air storage tanks etc.
The "Joint Efficiency" reflects your confidence in the welded seam areas of the as-manufactured pressure vessel.
Thickness of Circumferential Shells Under Internal Pressure
Thickness of Circumferential Shells Under Internal Pressure:
Design Variables:
(P) = Design Pressure (internal) (psi) =
(R) = Inside radius of shell under consideration (in.) =
(S) = Max. Allowable Stress Material (psi) =
(E) Joint Efficiency (80% = .80) =
Result:
Minimum required wall thickness of shell (inches) =
