Engineers Edge
Area Moment of Inertia Section Properties
Rectangle Calculator Section Through Corners
Strength of Materials
Area Moment of Inertia Section Properties Rectangle Calculator Section Through Corners
Area Moment of Inertia Section Properties of Rectangle Calculator Section Through Corners Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Description
Equation
Area Moment of Inertia Section Properties = I
Moment of Inertia
Section Modulus = Z = I/y
Section Modulus
Radius of Gyration
Radius of Gyration
A = area
A = db
y = Distance to neutral axis
Distance
Variables
Inputs:
"d"  (Width)
"b"  (Height)
Properties:
Area Moment of Inertia Section Properties (Units4)
Section Modulus (Units3)
Radius of Gyration (Units)
Extreme Point (Units)
Area (Units2)
