Area Moment of Inertia Section Properties: Triangle Calculator
Section Properties Equations and Calculators
Area Moment of Inertia Section Properties: Triangle Section Properties Calculator
Area Moment of Inertia Section Properties of Triangle Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Triangular Section
Variables
Inputs Inch mm
Length h (in, mm) =
Length b (in, mm) =
Calculated Properties
Area Moment of Inertia Section Ix (in4, mm4) =
Area Moment of Inertia Section Ix' (in4, mm4) =
Area Moment of Inertia Section Iy (in4, mm4) =
Area Moment of Inertia Section Iy' (in4, mm4) =
Distance x (in, mm) =
Distance y (in, mm) =
Area (Unit2) =
Triangle Section Equation Used
Description
Equation
Area Moment of Inertia Section Properties Ix (in4, mm4) =
bh3 / 36
Area Moment of Inertia Section Properties Ix' (in4, mm4) =
bh3 / 12
Area Moment of Inertia Section Properties Iy (in4, mm4) =
hb3 / 36
Area Moment of Inertia Section Properties= Iy' (in4, mm4) =
hb3 / 12
Distance to neutral axis x (in, mm) =
b / 3
Distance to neutral axis y (in, mm) =
h / 3
area A (in2, mm2) =
bh / 2
