Soil Foundary Spring Calculator
Civil Engineering Design Resources
Mat Boundary Spring Generator
INPUT DATA & DESIGN SUMMARY
FOUNDATION LENGTH L = ft
FOUNDATION WIDTH B = ft
GRID TRIBUTARY AREA A = ft2
MODULUS OF SUBGRADE K1 = lb / in3
(Obtained from the soil report?? for 1' x 1' sf plate load test,
???? in the absence of a soil report obtain from table below )
  INSIDE SPRING VALUE   kips / joint
  EDGE SPRING VALUE   kips / joint
  CORNER SPRING VALUE   kips / joint
ANALYSIS
        ( for B = L )
        ( for B < L )
          = lb / in3?????? =
          =   lb / in3?????? =
      TYPICAL VALUES OF MODULUS OF SUBGRADE REACTIONS,???? K1???? (lb / in3 )
                      MOISTURE CONTENT
    TYPE OF MATERIAL     ??1 to 4%   ??5 to 8%   ??9 to 12%   ??13 to 16% ??17 to 20% ??21 to 24% ??25 to 28% ??> 28%
  Silts and clays (liquid limit >50)     -   175   150   125   100   75   50   25
  ??(OH, CH, MH )
  Silts and clays (liquid limit <50)   -   200   175   150   125   100   75   50
  ??(OL, CL, ML )
  Silty and clay sands     300   250   225   200   150   -   -   -
  ??(SM & SH )
  Gravelly sands     Over 300???????????? 300   250   -   -   -   -   -
  ??(SW & SP )
  Silty and clayey gravels     Over 300???????????? Over 300???????? ?? 300   -   -   -   -   -
  ??(GM & GC )
  Gravel and sand     Over 300???????????? Over 300???????? ?? -   -   -   -   -   -
