Engineers Edge
Volume of Square Prism Equation and Calculator
Volume Equation and Calculation Menu
A square prism is a three dimensional solid figure whose bases are squares. In a square prism, the opposite sides and angles are congruent. A square prism is simply a cuboid with square base. I n the below figure, we can see that the bases are square . And, therefore, it is called as a square prism.
Square Prism
Input Length of Sides
Length a (in, mm) =
Length b (in, mm) =
Length c (in, mm) =
Result
Volume V (in3, mm3) =
Input Length and Volumes
Length b (in, mm) =
Length c (in, mm) =
Result
a (in, mm) =
Length a (in, mm) =
Length c (in, mm) =
Result
b (in, mm) =
Length a (in, mm) =
Length b (in, mm) =
Result
c (in, mm) =
© Copyright 2000 - 2020, by Engineers Edge, LLC www.engineersedge.com
Advertising | Contact | Privacy Policy
