Volume of Hollow Cylinder Equation and Calculator
Volume Equation and Calculation Menu
A cylinder is one of the most basic curvilinear geometric shapes, the surface formed by the points at a fixed distance from a given line segment, the axis of the cylinder. The solid enclosed by this surface and by two planes perpendicular to the axis is also called a cylinder. A hollow cylinder is one type of cylinder which is hollow.It has two radius,R is exradius,r is Inside circle radius
Hollow Cylinder
Input Volume Data
Length or Height h (in, mm) =
Radius R (in, mm) =
Radius r (in, mm) =
Result
Volume V (in3, mm3) =
Input Volume Data
Length h (in, mm) =
Outside Diameter (in, mm) =
Wall Thickness t (in, mm) =
Result
