Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
Structural Materials Menu
Engineering Materials Menu
This webpage details Section Properties for Structural Steel Angle BSI BS EN 10056.
Structural Steel Angle Equal Leg Section Properties: This European Standard specifies requirements for the nominal dimensions of hot-rolled equal and equal leg angles. This European Standard does not apply to angles with square roots. Tolerances for equal and unequal leg angles are given in EN 10056-2.
Shape Designation
d x bw x t
Section Dimensional Data
Inside Corner
Radius
External Edge
Radius
Area of
Section
d (mm)
t (mm)
R1 (mm)
R (mm)
A (cm2)
250 x 250 x 35
250
35
18
9
163
250 x 250 x 32
250
32
20
10
150
250 x 250 x 28
250
28
18
9
133
250 x 250 x 25
250
25
20
10
119
200 x 200 x 24
200
24
18
9
90.6
200 x 200 x 20
200
20
18
9
76.3
200 x 200 x 18
200
18
18
9
69.1
200 x 200 x 16
200
16
18
9
61.8
180 x 180 x 18
180
18
18
9
61.9
180 x 180 x 16
180
16
18
9
55.4
160 x 160 x 15
160
15
17
8.5
46.1
150 x 150 x 18
150
18
16
8
51
150 x 150 x 15
150
15
16
8
43
150 x 150 x 12
150
12
16
8
34.8
150 x 150 x 10
150
10
16
8
29.3
130 x 130 x 12
130
12
14
7
30
120 x 120 x 15
120
15
13
6.5
33.9
120 x 120 x 12
120
12
13
6.5
27.5
120 x 120 x 10
120
10
13
6.5
23.2
120 x 120 x 8
120
8
13
6.5
18.7
100 x 100 x 15
100
15
12
6
27.9
100 x 100 x 12
100
12
12
6
22.7
100 x 100 x 10
100
10
12
6
19.2
100 x 100 x 8
100
8
12
6
15.5
90 x 90 x 12
90
12
11
5.5
20.3
90 x 90 x 10
90
10
11
5.5
17.1
90 x 90 x 9
90
9
11
5.5
15.5
90 x 90 x 8
90
8
11
5.5
13.9
90 x 90 x 7
90
7
11
5.5
12.2
90 x 90 x 6
90
6
11
5.5
10.6
80 x 80 x 10
80
10
10
5
15.1
80 x 80 x 8
80
8
10
5
12.3
80 x 80 x 6
80
6
10
5
9.35
75 x 75 x 8
75
8
9
4.5
11.4
75 x 75 x 6
75
6
9
4.5
8.73
70 x 70 x 10
70
10
9
4.5
13.1
70 x 70 x 8
70
8
9
4.5
10.6
70 x 70 x 7
70
7
9
4.5
9.4
70 x 70 x 6
70
6
9
4.5
8.13
65 x 65 x 7
65
7
9
4.5
8.7
60 x 60 x 10
60
10
8
4
11.1
60 x 60 x 8
60
8
8
4
9.03
60 x 60 x 6
60
6
8
4
6.91
60 x 60 x 5
60
5
8
4
5.82
50 x 50 x 8
50
8
7
3.5
7.41
50 x 50 x 6
50
6
7
3.5
5.69
50 x 50 x 5
50
5
7
3.5
4.8
50 x 50 x 4
50
4
7
3.5
3.89
50 x 50 x 3
50
3
7
3.5
2.96
45 x 45 x 6
45
6
7
3.5
5.09
45 x 45 x 5
45
5
7
3.5
4.3
45 x 45 x 4.5
45
4.5
7
3.5
3.9
45 x 45 x 4
45
4
7
3.5
3.49
45 x 45 x 3
45
3
7
3.5
2.66
40 x 40 x 6
40
6
6
3
4.48
40 x 40 x 5
40
5
6
3
3.79
40 x 40 x 4
40
4
6
3
3.08
40 x 40 x 3
40
3
6
3
2.35
35 x 35 x 4
35
4
5
2.5
2.67
30 x 30 x 5
30
5
5
2.5
2.78
30 x 30 x 4
30
4
5
2.5
2.27
30 x 30 x 3
30
3
5
2.5
1.74
25 x 25 x 5
25
5
3.5
1.75
2.26
25 x 25 x 4
25
4
3.5
1.75
1.85
25 x 25 x 3
25
3
3.5
1.75
1.42
20 x 20 x 3
20
3
3.5
1.75
1.12
