Uniform Loading Horizontal Projected Area Spherical Cylinder Stress and Deflection Formulas and Calculator
Spherical Cylinder Stress and Deflection Uniform loading, w force/unit area; on the horizontal projected area; tangential top edge support Equation and Calculator.
Preview: Spherical Cylinder Stress and Deflection Internal or External Pressure Calculator
Spherical Cylinder
Uniform loading,
Deflection and Stress Uniform loading, w force/unit area; on the horizontal projected area; tangential top edge support.
For R2 / t > 10& θ ≤ 90°
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Change in height dimension y
Where used:
v = Poisson's ratio
w = Force applied (lbs/in2)
σ1,2 = Stress, (lbs/in2)
R2 = Radius (in)
y = Depth as indicated (in), Must be equal too or less than d
t = Wall thickness (in)
θ = Angle (deg.)
