Stress in Cone or Conical Section Seam Equations and Calculator
Pressure Vessel Design and Engineering
Stress in Cone or Conical Section Seam Equation and Calculator
The stress in the girth seam will govern only when the circumferential join efficiency is less than one - half the longitudinal joint efficiency, or when the internal pressure additional loadings (wind load, reaction of saddles) are causing longitudinal bending or tension . The reason for it is that the stress arising in the girth seam pound per square inch is one - half of the stress in the longitudinal seam.
Preview
Stress in Cone or Conical Section Seam Calculator:
Required minimum wall thickness
t = [ P (D + 2CA) ] / ( 2 cosα (SE - 0.6P) + CA
Maximum allowable working pressure
P = 2SEta cosα / ( D + 1.2 ta cosα )
P = Design pressure or max. allowable working pressure, psi
S = Rated stress value of the material
E = Weld Joint efficiency
R = Inside radius, inches
D = Inside diameter of vessel , inches
α = Angle in Degrees
t = Thickness of shell (wall), inches
ta = Wall thickness used in actual design, inches
CA = Corrosion allowance, inches
- The half apex angle, α not greater than 30° .
Example:
Given:
P = 100 psi design pressure
S = 17,500 psi stress value of SA 515-70 plate @ 650°F
E = 0.85, efficiency of of spot welded joints
D = 96 inches
R = 48 inches
α = 30°
CA = 0.125 in
Shell thickness requirements:
t = ( 100 psi x 96.25 in.) / ( 2 x 0.866 x (17,500 psi x 0.850 - 0.6 x 100 psi) + 0.125 in.
t = 0.500 in.
Probably use 0.500 in. plate for design = ta
Maximum working pressure
ta = ( 2 x 17,500 psi x 0.85 x 0.500 in x 0.866) / ( 96.00 in + 1.2 x 0.500in x 0.866)
ta = 133 psi
