Stress and Deflection Vessel Weight Formula and Calculator
Any smooth figure of revolution if R2 is less than infinity Stress and Deflection Equation and Calculator.
Own weight, δ force/unit volume; tangential top edge support. W = weight of vessel below the level y.
Preview: Smooth Figure of Revolution Stress and Deflection Calculator
Smooth Figure of
Revolution
For R2 / t > 10 and at any level y below the liquid surface, y < d
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Where used:
v = Poisson's ratio
W = Weight of vessel (lbs)
δ = Density (lbs/in3
σ1,2 = Stress, (lbs/in2)
R1 = Radius (in)
R2 = Radius (in)
t = Wall thickness (in)
d = Liquid level (in)
y = Vertical level from bottom of vessel (in)
θ = Angle (deg.)
