Spherical Cylinder Stress and Deflection Equation and Calculator
Spherical Cylinder Stress and Deflection by Uniform internal or external pressure, q force/unit area; tangential edge support Equation and Calculator.
Preview: Spherical Cylinder Stress and Deflection Internal or External Pressure Calculator
Spherical Cylinder |
Uniform internal
or external pressure ![]() |
Deflection and Stress by Uniform internal or external pressure, q = force/unit area; tangential edge support.
For R2 / t > 10
Meridional Stress & Circumferential Hoop Stress
Change in height dimension y
ψ = 0
Where used:
v = Poisson's ratio
q = Applied pressure (lbs/in2)
σ1,2 = Stress, (lbs/in2)
R2 = Radius (in)
R = Distance as indicated (in)
t = Wall thickness (in)
θ = Angle (deg.)
