Cone Cylinder Tangential loading only Stress and Deflection Equation and Calculator
Cone Cylinder Stress and Deflection by Tangential loading only; resultant load = P. Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
Preview: Cone Cylinder Stress and Deflection by Tangential loading only; resultant load = P Calculator
Cone Cylindrical
Deflection and Stress by Tangential loading only; resultant load = P.
r must be finite to avoid infinite stress and r/t > 10 to be considered thin-walled
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Change in height dimension y
Angle
α = tan-1 ( ( R-r ) / y)
Where used:
v = Poisson's ratio
P = Applied resultant axial load (lbs)
σ1,2 = stress, (lbs/in2)
R = Large radius (in)
r = Small radius (in)
α = Angle (deg.)
