Related Resources: power transmission
Universal Joint Maximum Minimum Speed
Power Transmission and Technology
The Universal Joint. - This form of coupling, originally known as a Cardan or Hooke's coupling, is used for connecting two shafts the axes of which are not in line with each other, but which merely intersect at a point. There are many different designs of universal joints or couplings, which are based on the principle embodied in the original design. One well known type is shown by the accompanying diagram.
As a rule, a universal joint does not work well if the angle α (see illustration) is more than 45 degrees, and the angle should preferably be limited to about 20 degrees or 25 degrees, excepting when the speed of rotation is slow and little power is transmitted.
Universal Joint
Universal Joint
Variation in Angular Velocity of Driven Shaft: Owing to the angularity between two shafts connected by a universal joint, there is a variation in the angular velocity of one shaft during a single revolution, and because of this, the use of universal couplings is sometimes prohibited. Thus, the angular velocity of the driven shaft will not be the same at all points of the revolution as the angular velocity of the driving shaft. In other words, if the driving shaft moves with a uniform motion, then the driven shaft will have a variable motion and, therefore, the universal joint should not be used when absolute uniformity of motion is essential for the driven shaft.
Determining Maximum and Minimum Velocities:
If shaft A (see diagram) runs at a constant speed, shaft B revolves at maximum speed when shaft A occupies the position shown in the illustration, and the minimum speed of shaft B occurs when the fork of the driving shaft A has turned 90 degrees from the position illustrated.
The maximum speed of the driven shaft may be obtained by multiplying the speed of the driving shaft by the secant of angle α. The minimum speed of the driven shaft equals the speed of the driver multiplied by cosine α. Thus, if the driver rotates at a constant speed of 100 revolutions per minute and the shaft angle is 25 degrees, the maximum speed of the driven shaft is at a rate equal to 1.1034 × 100 = 110.34 rpm. The minimum speed rate equals 0.9063 × 100 = 90.63; hence, the extreme variation equals 110.34 − 90.63 = 19.71 rpm.
Smax = S1 · ( 1 / cosα )
Minimum speed of the driven shaft
Smax = S1 · cosα
Truck and Car Universal Joint Design and Engineering Equation
Machinery's 30th edition
