V-Belt Angle Between Two Sheave
V-Belts Design and Engineering
V-belts are used to transmit power from motors to machinery. Sheaves have a V-groove. Pulleys have a flat circumference. A V-belt may be used in combination with a drive sheave on a motor shaft and a pulley on the driven shaft.
Equation and Calculator to determine the v-belt angle between the two sheave pulley's.
All calculators require a Premium Membership
