The webpage is not working since JavaScript is not enabled. Most likely, you are viewing using Dropbox website or another limited browser environment.
Calculation by Sling Angle
Total Weight (W)
lbs
Input Variable
Weight on EQUAL loaded slings
lbs
Sin(a1)=
Sin(b2)=
Cos(b1)=
Cos(b2)=
Sling angle a1=
Deg.
Sling Angle a2=
Deg.
Vertical Force V1
lbs
Vertical Force V2=
lbs
Horizontal Force H1
lbs
Horizontal Force H2=
lbs
Tension Force Sling T1
lbs
Tension Force Sling T2=
lbs
Calculation by Sling & Vertical Length Known
Total Weight (W)
lbs
Vertical Weight on EQUAL loaded slings
lbs
Sling Length L1=
inches
Sling Length L2=
Inches
Vertical Length v1=
inches
Vertical Length v2=
Inches
Horizontal Length h1=
inches
Horizontal Length h2=
Inches
sin(a1) =
sin(a2)
cos(a1)=
cos(a2)
angle a1 =
Deg.
angle a2=
Deg.
angle b1 =
Deg.
angle b2=
Deg.
Vertical Force V1=
lbs
Vertical Force V2=
lbs
Horizontal Force H1=
lbs
lbs
Tension Force Sling T1=
lbs
lbs
Calculation by Sling & Horizontal Length Known
Total Weight (W)
lbs
lbs
Sling Length L1=
inches
Sling Length L2=
Inches
inches
Inches
Vertical Length v1=
inches
Vertical Length v2=
Inches
sin(a1) =
sin(a2)
cos(a1)=
cos(a2)
angle a1 =
Deg.
angle a2=
Deg.
angle b1 =
Deg.
angle b2=
Deg.
Vertical Force V1=
lbs
Vertical Force V2=
lbs
lbs
lbs
lbs
lbs
Update
Reset
Print
