Cone Stress and Deflection by Uniform rotation Equations and Calculator
Cone Cylinder Stress and Deflection by Uniform rotation, ω rad/s, about central axis Equation and Calculator.
Preview: Cone Cylinder Stress and Deflection by Uniform Rotation Calculator
By Rotation
Deflection and Stress by Uniform rotation, ω rad/s, about central axis.
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Change in height dimension y
Where used:
v = Poisson's ratio
ω = Uniform rotation (rad/sec)
δm = Mass Density (lbs/in3
σ1,2 = stress, (lbs/in2)
R = Large radius (in)
α = Angle (deg.)
