Ball Screw Design Equations and Selection Criteria
Machine Design Resources
Gear Design and Engineering
A ball screw transforms rotational motion into transitional motion. As a result, the shaft is subject to loads:
Ball Screw Design Equations and Selection Criteria:
  • Applied load
  • Required Torque
  • Maximum Rotational Speed
  • Resonance (bending) of threaded shaft
  • DN force ball screw
  • Ball screw life, basic dynamic rating
  • Stiffness
  • Accuracy
Driving Torque to Obtain Thrust
T = Driving torque (Nm)
Fa = Axial thrust force on ball screw (N)
l = Screw lead (m)
η = Efficiency
Thrust Required
Thrust is equal to the sum of all forces acting in the axial direction
Fa = FM + Ff + Fi + Fg
FM = Machining force (N)
Ff = Frictional force (N)
Fi = Inertial force (N)
Fg = Gravitational force (N)
Stresses from Applied Loads
Axial Load
Torsional load
Fa = Applied axial force (N)
rtr = root radius = root diameter / 2 (m)
T = Applied Torque (N-m)
π = 3.14159
Equivalent (Von Mises) Stress
Von Mises stress
Stress equation
Compressive Load
Compressive load
P1 = Buckling load [N]
lb = Distance between mounting positions [m]
E = Elastic modulus [Pa]
I = Second moment of inertia [m4]
λ = Support factor
Fixed – free: λ = 0.25
Fixed – supported: λ = 2.0
Fixed – fixed: λ = 4.0, Fixed -supported = 2.0, Fixed-free = 0.25
Fixed - Free Configuration
Simple - Simple Configuration
Fixed - Simple Configuration
Fixed - Fixed Configuration
Basic Static Loading
  • When ball screws are subjected to excessive loads in static condition (non rotating shaft), local permanent deformations are caused between the track surface and the steel balls.
  • When the amount of this permanent deformation exceeds a certain degree, smooth movement will be impaired.
Coa = Basic static load rating [N, kgf, lbf]
Fs = Static safety factor
Fa = Load on shaft in axial direction [N, kgf, lbf]
Use Fs (Lower Limit)
Normal 1.0 - 2.0
With Impacts
and
Vibrations
3.2 - 3.0
Permissible Ball Screw Speed
When the speed of a ball screw increases, the ball screw will approach its natural frequency, causing a resonance and the operation will become impossible.
nc = Critical speed [min-1]
lb = Distance between supports [m]
E: Elastic modulus [Pa]
ρ = Density [kg/m3]
A = Root cross sectional area [m2]
λ = Support factor
Fixed – free: λ = 1.875
Supported – supported: λ = 3.142
Fixed – supported: λ = 3.927
Fixed – fixed: λ = 4.730
Spindle Speed and DN Drive
n = Va / l
n = Revolutions per second ( s-1 )
Va = Axial Speed (m/s)
l = Lead (m)
DN unless otherwise specified
DN ≤ 70000
D = Ball circle diameter (mm)
N = Revolutions per minute (min-1)
Dynamic Load Rating Ca and Life
The basic load rating Ca is the load in the shaft direction with 90% of a group of the same ball screws operating individually will reach a life of 106 (1 million) revolutions.
Dynamic Load Rating
L = Rotation life [rev]
Ca = Basic dynamic load rating [N, kgf, lbf]
fw = Load factor
Fa = Load in shaft direction [N, kgf, lbf]
Use fw
Smooth operation no impacts 1.0 - 1.2
Normal operation 1.2 - 1.5
Operation with impacts and vibrations 1.5 - 2.5
Running Lengths depending on Usage
Running distance during acceleration:
Running distance during deceleration:
THK Co. Ltd
Nook Industries
University of Utah, Mechanical Engineering ME EN 7960
