Convertible Sofa Bunk Mechanism | |||
Post Reply |
Mechanical Engineering Forum |
Posted by: lilduka ® 08/04/2010, 10:24:06 Author Profile eMail author Edit |
Hi friends,
We are designing a convertible bunk bed sofa system, as you see on the picture we are holding the back side of the sofa as bunks' upper bed. Holding configuration is so easy and enjoyable with block lift (controlable gas piston) by pressing the pistons pedal. The handicap is to fold the bunk to sofa position. We have two independent holding arms, you can see on the picture, they are slidig and turning by the way when the system goes sofa to bunk. When we want to fold the system bunk to sofa, we have to force two arms simultaneously, it is the difficulty of the system. Which trick can solve this problem?
Post Reply Tell a Friend (must be logged in) Alert Admin About Post |
Previous | | |
© Copyright 2000 - 2024, by Engineers Edge, LLC All rights reserved. Disclaimer
