Heat Sink Design | ![]() | ||
Post Reply |
Mechanical Engineering Forum |
Posted by: PhilMech ® 12/22/2010, 15:26:04 Author Profile eMail author Edit |
I am looking for a material recommendation for a heatsink being designed. I have a board that I need to dissipate about 5W of power from. The size of the heatsink is about 3x3x.5 inches. The sink will come into contact with a thermal pad which will make contact with and aluminum enclosure. Can someone make a recommendation on a good grade of aluminum to use here and the manufacturing process(cast,machined). Thanks, Phil |
Post Reply Tell a Friend (must be logged in) Alert Admin About Post |
View All | Previous | Next | |
Replies to this message |
: Heat Sink Design | ![]() | ||
: Heat Sink Design -- PhilMech |
Post Reply |
Top of thread |
Posted by: linuxpenguin ® 01/31/2011, 08:26:29 Author Profile eMail author Edit |
5w of heat isnt very much, so pretty much any grade aluminum can be used. Is there a reason you arent going to use copper? simple, bead welded design would work fine.
Where am I? Original Top of thread | Previous | | |
© Copyright 2000 - 2024, by Engineers Edge, LLC All rights reserved. Disclaimer
