Rubber Grommets Review
Mechanical Components Menu
Rubber Grommets are any variation of rings or eyelets, which are used as a insulation device. Grommets are normally inserted into a hole in a mechanical part to prevent chafing, grounding or mechanical rubbing. Grommets are commonly used in bulkheads, walls, or other obstructions where a wires, hoses or tubes must pass through. Grommets are available in many different material, sizes and shapes.
Grommets are available in pre-molded rubber, plastic and composites. Grommets are also available in most any extruded cross section and provided as a roll for cutting to custom length requirements.
Rubber Grommet Various Sizes
Rubber Grommet
