Thermal Linear Expansion of AISI 303 Stainless Steel
Heat Transfer Engineering
Thermodynamics
Engineering Physics
AISI 303 stainless steel, which is a modification of the basic 18-8 austenitic stainless steel, contains higher amounts of phosphorous (0.20% max) and sulfur (0.15% min.). The high sulfur content makes it more machinable and possibly improves its ductility. The other variation of this steel is AISI 303Se stainless steel. This contains selenium (0.15%) which is added for the same reason given above. Since these elements are present in relatively small quantities (:0.20%), the thermal expansion of these steels are very close to that of the more common type, AISI 304, although their mechanical properties are quite different.
The recommended values are tabulated below. The uncertainty in the values of the thermal linear expansion, the mean coefficient, and the instantaneous coefficient is within ±5%, ±5%, and ±10%, respectively.
Temperature (K) |
Thermal Linear Expansion (%) |
Instataneous Coefficient of Thermal Linear Expansion ( 10-6 K-1 ) |
Mean Coefficient of Thermal Linear Expansion ( 10-6 K-1 ) |
10 |
-0.338 |
1.10 |
11.94 |
20 |
-0.334 |
7.85 |
12.23 |
30 |
-0.325 |
8.72 |
12.36 |
40 |
-0.316 |
9.31 |
12.49 |
50 |
-0.307 |
9.78 |
12.63 |
60 |
-0.297 |
10.17 |
12.75 |
70 |
-0.286 |
10.49 |
12.83 |
80 |
-0.276 |
10.80 |
12.96 |
90 |
-0.265 |
11.09 |
13.05 |
100 |
-0.254 |
11.39 |
13.16 |
150 |
-0.194 |
12.38 |
13.57 |
200 |
-0.130 |
13.22 |
13.98 |
250 |
-0.062 |
14.05 |
14.37 |
273 |
-0.029 |
14.38 |
14.57 |
293 |
0.000 |
14.71 |
300 |
0.010 |
14.90 |
14.78 |
350 |
0.086 |
15.60 |
15.18 |
400 |
0.167 |
16.27 |
15.61 |
500 |
0.338 |
17.50 |
16.33 |
600 |
0.519 |
18.58 |
16.91 |
700 |
0.709 |
19.49 |
17.42 |
800 |
0.907 |
20.20 |
17.89 |
900 |
1.112 |
20.69 |
18.32 |
1000 |
1.323 |
21.04 |
18.71 |
1100 |
1.536 |
21.25 |
19.03 |
1200 |
1.748 |
21.36 |
19.27 |
1300 |
1.959 |
21.40 |
19.45 |
1400 |
2.171 |
21.45 |
19.61 |
1500 |
2.386* |
21.52* |
19.77* |
1600 |
2.601* |
21.61* |
19.90* |
1670§ |
2.753* |
21.69* |
19.99* |
* Extrapolated values.
Disclaimer
| Feedback | Advertising
| Contact
