Thermal Contact Conductance Metal Surfaces Air
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Thermal contact conductance of some metal surfaces in air (from various sources)
Material
Surface Condition
Roughness
µm
Temperature
°C
Pressure
MPa
hc*
W/m2· °C
Identical Metal Pairs
416 Stainless steel
Ground
2.54
90–200
0.3–2.5
3800
304 Stainless steel
Ground
1.14
20
4–7
1900
Aluminum
Ground
2.54
150
1.2–2.5
11,400
Copper
Ground
1.27
20
1.2–20
143,000
Copper
Milled
3.81
20
1–5
55,500
Copper (vacuum)
Milled
0.25
30
0.7–7
11,400
Dissimilar Metal Pairs
Stainless steel-
Aluminum
20–30
20
10
20
2900
3600
Stainless steel-
Aluminum
1.0–2.0
20
10
20
16,400
20,800
Steel Ct-30-
Aluminum
Ground
1.4–2.0
20
10
15–35
50,000
59,000
Steel Ct-30-
Aluminum
Milled
4.5–7.2
20
10
30
4800
8300
Aluminum-
Copper
Ground
1.3–1.4
20
5
15
42,000
56,000
Aluminum-
Copper
Milled
4.4–4.5
20
10
20–35
12,000
22,000
*Divide the given values by 5.678 to convert to Btu/h · ft2 · °F.
Thermal Contact Resistance
  • Derived from CRC Handbook of Chemistry and Physics - 56th edition
  • Maya Engineering Data Heat Exchangers
